Could be that your carb nozzle is worn slightly being the bike is older. Verify the float height as well. DDKs are close is every 250 I've had. Try the DDL, it's cheap. Try the others as well. The NECF in my bike is especially good, very strong off the bottom, smooth idle, and smooth midrange. The leaner dia. in this series were terrible. If you like smooth power work with this series in the F and maybe G dia. I'm running a 45 pilot and 178 main with these, a 180/182 main with the JD Blue or DDx .
