Jetting help - Fuel consumption
Jakobi
Hi everyone.
I'm looking for a bit of assistance. I'd like to know what others are using in the 2010 model EC's. Even other years will suffice, and how many KM you can get out of a tank before reserve.
Stock the bike had: 40, N1EF#1, 175 - The bike started easily and ran strong, however really poor fuel consumption, would smoke alot, and load up in the tight. It also suffered a burble in the mid range before coming onto full noise which got worse as it would load up.
Current: 40, N3EG#2, 175 - Bike feels less torqey and more snappy down load and into the mid. Nice transition into mid range where it continues to pull hard. Feels to sign off a bit on the top end. Bike also ran quite warm after giving it some abuse. Plugs read nicely.
Also, is there an easy way to access the bowl (main and pilot). Theres not much room under the carb and the tank stops it from rotating out.
Thanks, Jake
Sorry forgot to add that.
Its a 2010 EC300 Race.
Temp 20 - 35C
Humidity 65 - 100%
Elevation 0 - 500M
I think the 40 PJ is fine... a 38 is too lean for most conditions and the MJ seems in the ballpark.
So, I'd look to the needle and possibly a MJ adjustment.
Some of the GG needles I have seen vary quite a bit in the middle, can't remember the # but one was fairly fat and thinned down quickly in it's taper.
Might be what you have, as you open the throttle it dumps too much fuel too quickly.
Some wide open plug chops should tell you how spot on the MJ is, if it's close then the needle is where I would concentrate my efforts.
Drop it and see if there's and improvement...if so your on the right track.
Hope that helps.
Thanks Mate.
I have settled with the N3EG#2, 40P, 175M, for now. If the N1EF wasn't already on top clip I'm sure one more up would have done it.
The N3EG#3 is too rich. A bit richer than N1EF#1. N3EG#2 is leaner up till 5/8ths and then richens up onto the main.
Plug chops are all reading perfect. Seat of the pants is crisp and responsive with a strong pull as you hold the throttle open.
Now I just have to set my mind at peace and ride on! I plan on getting another friend with some experience to take it for a ride to see what their impressions are.
Thanks again.
Will report back on fuel economy after the next ride:D
N1EF#1 was 7L for 70km.
I am using an N3EH needle and am at about 1000m, but only get about 75km on a full tank
The only difference between the EG and the EH is up to 1/4 throttle where the G is a bit richer. What would make more difference is what clip position you are running it on.
Do you know what clip? Also what Pilot and Main? What year bike?
I'm not sure why my bike is loving it so lean. If I move back to 3rd clip its rich to the point it won't rev cleanly and spooge runs from my pipe..
Not any help here but GG should not be delivering a bike with the stock needle position having to be in the #1 clip position. This has been reported by more than a few for the new bikes N1EF #1 position stock and still people say the bikes are to rich or run poorly. With no where to go in adjustment range for leaner operation clearly the wrong needle IMO.
Sorry for the mini rant....
2010 ec 300
N1EF mid clip
MJ 175
PJ 42
Consumption much the same as Swazi 70-75km per tank.
On open stuff riding on the pipe,it is really thirsty.Got caught out once.
2010 ec 300
N1EF mid clip
MJ 175
PJ 42
Thats not really good economy at all :( Hopefully mine should be a tad better now that I've leaned out the mid range.
I'm feeling pretty good with N3EG#2. Comparitively its only just a bit leaner than the N1EF#1. and N3EG#3 is still too rich for my bike to handle.
Do you think I just have a freak machine?
I also agree. GG shouldn't be shipping on the top clip. The manual doesn't provide any kind of table of what needles to try either. About the only complaint I have at the moment. I'll be discussing matters with the dealer when I head in for my 500km first service.
What slide do you have?
Given that the n1ef isn't a great needle - it tends to drive folks to lean the pilot and crank up the idle to supply more fuel off the needle. (this is referred to pulling over).
One key thing you want drive for is to end up with a setting where you have the idle screw backed out so that the bottom (pilot circuit) and mid (needle circuit) are properly separated and can be properly tuned. Note that with the n1ef needle they aren't separated well and one symptom of this is the air screw doesn't have much effect and the idle screw can be cranked in to the point of coil bind on the tension spring - and even then it might not idle well...
So when you switch from the n1ef to n3eg (or when others switch to keihin straight taper needles - cek, ddk, etc. or JD jetting, etc.) In my opinion, you should back out the idle screw to lower the slide and needle to separate the circuits (pilot & needle) Running a leaner needle, and resetting idle, you typically go up one or two sizes on the pilot to balance things out. Note that this isn't going richer on the bottom - it's just making the pilot circuit supply more fuel and have less fuel come through needle circuit - to better separate these circuits.
With the circuits properly separated - it's easier to adjust, is less finicky to temp and altitude changes, and has a smoother transition from the low to mid - where it will typically burble then "hit" as it clears out with the "bad jetting".
Be sure to reset your air screw. Note that the air screw on this carb can be 2 and half turns out and everything is fine...
And given all of the above - check to make sure you have a #7 slide or leaner...
The carb itself suffers from a lack of sensitivity to adjustment that drives folks to jet it badly - this is one thing that RB-Designs resolves with his carb mods - he internally modifies the carb (inside the carb block) to fix this - this along with a slide, needle, brass and a thin divider plate to increase velocity at low rpms makes it work well across the rpms.
Others have mentioned having your combustion chamber shaped for optimal squish and compression - RB-Designs is the place to use for this service in the u.s. - best price and extremely high quality work.
Thanks for the additional info Webmaster.
Can confirm the slide is a #7. I have had a play with the air screw and the idle adjustment. While I haven't screwed them right in, after changing to the N3EG I had to turn the air in half a turn, and backed the idle back down a turn (it doesn't appear to be turned right in either)
To add to this, with both setups response was crisp and clean off the bottom end. N1EF felt to be too rich on transition from the straight to the taper (mid range) where it would load, burble, clear, and hit.
Would you suggest turning the air screw right in? If it still runs this would indicate I'm too lean on the pilot - correct? and would require a set richer. Is my understanding right?
One other thing. With the N1EF#1 the bike would not idle once warm. I never made any adjustments on the idle screw to try and resolve this. It idles perfectly with the N3EG#2 hot or cold
I think I see what you mean Webmaster.
I was tinkering around today. I now have the needle on clip 1 (which is perfect), but as you said. Both the idle screw (in) and Air screw (out) are at their max and don't make alot of difference.
I was under the impression I would have to lean the pilot circuit to get it to idle with the idle screw out. It feels quite doughy off the bottom and gets better as I lean the mixture.
Also, is it possible to change the pilot without removing the whole carb?
On older models - you could :
  1. Loosen the clamps on the carb (insulator and airboot) and rotate the top of the carb towards you.
  2. You then have room to remove the slide.
  3. With the slide removed - you now have from to rotate the bottom of the carb towards you with room to remove the carb bowl and access the jets.
I would assume you can do the same with the newer frame....
That sounds like the plan! Should work! Thanks again
Nothing works :(
Go Richer on the pilot and it still just dies. Idles worse.
I found by leaning the pilot out it did help. I'm still having to turn the idle screw in considerably to get any kind of idle regardless of what pilot I use.
I'm going to stick to the 38 for now.
Do I need a needle with a leaner straight section? It came stock with a N1EF, i'm now on a N3EG. I like the profile of the N3 tapers better. Whats leaner than EG? EH?
Did you turn down the idle adjuster screw when you installed the richer pilot jet?
I haven't used the n3eg - it is leaner than the n1ef? Yes?
Yeah Jeff,
Its a bit leaner off idle, leaner again through mid, and then richens up onto the main.
I have found a level where I can get good idle adjustability with the 38 Pilot. The idle screw would be about 3/4's of the way in. Looking through the top of the carb you can see that the screw has taken up pretty much all the threading. Looking in the throat of the carb I hardly noticed the slide moving at all when making adjustments on the screw for the other 3/4's of adjustment.
Anyway, I have a nice idle now that lifts the front end cleanly off idle without any clutch, without any stalling. I can't complain.
Over all my whole setup is quite lean
38 P
N3EG#1 (N1EF#1 was burbly rich)
175 M
Tan plug, revs cleanly. Clip #2 wasn't as clean up to half throttle, but felt like it pulled harder from there.
Fuel wise, I used 6.5L to do 75km. (That was on clip 2)
