swazi_matt
Active member
I have just done a top and bottom rebuild of my bike as well as a bunch of other maintenance
I finally got it all buttoned up and took it for a run in ride. It runs fine low down but when it would normally go into power band it starts spluttering and never kicks in - previously it would splutter a bit just before going into power band if the bike was cold after a long slow downhill for example
The guys that did the bottom end for me mostly work on ktms and commented that they had battled a bit working out the power valve mechanism and when I reassembled it ( they only had the bottom) the powervalve seemed to have a bit more preload than I remember
I did not change any jetting and used the same thickness base gasket so I am inclined to think that it is not jetting but before I open the powervalve up I thought I would ask here
