2 sets of center cases- $200 for each set
2 crank shafts- $100 for each
2 Basket ring gears, on large bore one small $75 each
6 speed transmission, needs new counter shaft $150
Boyseen Reed cage $40
V force reed cage $45
Rear brake setup. Pedal, master, slave, carrier, $100
Rear brake parts. Master and slave bodies $40
Front brake setup. Master, slave, lever, line $100
Clutch cover $40
Bent radiators $20
2 rear axles with adjuster blocks $25 each
Swingarm pivot bolt $20
2 power valve ball ramp assemblies $35 each
Domino throttle housing shell $25
Fuel tank $30
2 swingarms with linkage and rocker $100 each
2 frames make offer
coil $10
Clutch cover $40
Bent radiators $20
Fuel tank $30
2 frames make offer
coil $10
