Can you please send me sone photos of the tank
I have a large stash of parts that will not fit my new orange bike and its time to move on so I am going to be selling all the parts I have collected in the last 16yrs of riding these Spanish stallions.
nice did u rims, no rotor or sprocket---$400
Well used did u rims, good for practice, includes half used 49t ironman and galfer floating rotor--- $300-
45mm zoke front end with clamps and axle --- $300
50mm zoke front end with clamps and axle --- $300
07 sachs shock---$175
05 sachs shock---$175
Barnett Clutch BAsket with ring gear, needs new dampers $200
two crakshafts, both should be rebuilt---$100 each
two sets of cases--- $200 for each set
Transmission--- $200
Transmission with worn out counter shaft---$100
300 cylinder, likely needs replating- $75
Two Right side outer covers---$100 each
Two swingarms with linkage $100 each
05 frame $100
07 frame $100
Stock tank $50
Clark oversized tank with petcock and tusk cap $85
Three sets of radiators $65 each
One Oem carb $50
Two kickstarter Gear setups $35 each
One 06 race ignition, its stamped gncc map or some such thing---$75 these should be sold as a set with stators as I spliced new connectors in
ANother ignition $50
2k3 stator $50
2k2 stator $40
Clutch master and slave, was on running bike Slave is worn from chain $75
Front Brake caliper and master $75
Rear Brake caliper and master $75
Wa state title, street legal, matches numbers on one of the case sets---make offer
05 subframe and airbox---$75
05 Tweaked LTR GG/xr400 chainguide converter --- $50 Just need to be straightened out
Lots of little odds and ends and well used plastics
Pics available on request. I will try to keep this list updated as stuff sells!
