gasser
I definitely want to make this mod to my bike. I want to retain the foot brake as well but I do not want to use the recluse LHRB set up. I have an older AJP clutch mc that I can use for the hand brake (it uses dot 4) and will retain my stock clutch mc (uses mineral oil) for the clutch. I plan on welding up a second handlebar mount as shown in these pictures: http://red450.smugmug.com/Other/Left-Hand-Brake/i-2rjfk2X
That leaves me with the part I need help with - the foot master cylinder. I've seen a video on youtube (https://www.youtube.com/watch?v=AkOzxM3yTRQ) where a fellow took out his oil sight window and welded over the hole then tapped the top (which he also welded shut)for the additional line from the hand brake mc. I would prefer to do this using a mc that has a remote reservoir (I could switch out with my son's 01 gasser). Do the older master cylinders that have a remote reservoir and no sight window have a good place to drill and tap for the second hydraulic line? I think I read somewhere that it would be better to have the second line attach somewhere low on the mc instead of at the top. Is that true? Any help would be greatly appreciated thanks - Ken
