losing coolant
Gassey fan
just been out riding and noticed that at low putt round revs i am losing coolant out the pipe by the rad cap is my rad cap stuffed or what i have got force rad guards on
could be stuffed rad cap or head gasket gone, easy fix either way:)
If you fill the radiators up all the way to the neck, a little fluid WILL come
out when you get 'er hot. Gassers like the fluid just over the top of the
slotted tubes inside, not much more. Gives enough room for when the
coolant warms and expands (it expands quite a bit, all fluids do)
I do really like to run the plastic expansion tank that fits around the frame
steering tube, it gives plenty of room for the coolant to expand into. Some
have experienced plastic failures of the tank, though.....YRMV
