yes, just make sure you have a degree of preload on the springs. And it would be worth reducing the oil gap to about 90mm (adding more oil) to improve bottoming resistance.
You can drop the yokes down the forks a little bit to lower it also. Just remember you are changing your geometry, so you need to set the rear sag to suit.
