We offer 3 different pull rod sets to lower or raise the seat height. We offer a 120 mm to raise the rear 10 mm. or 400". For lowering, our 124 mm will drop your seat height by 10 mm or .400" Our 126 mm will drop your seat height by 20 mm or .800"
If your bike is equipped with the correct shock spring for your weight, using the 126 mm may require you to spring up to the next rate. The 124 mm and 120 mm only require a pre load adjustment. This is considering the spring is correct for you.
In addition to changing the seat height with the pull rods, you are able to change the bikes handling and combine different fork heights in the triple clamps for your desired results.
You can give us a call if you would like more details or advice for your specific needs.
