LTR alloy water pump impeller.
When I talked with Les back in December, he didn't have any in stock and was not planing to have anymore made.
If you're boiling your bike I'd recommend engine ice. Instead of boiling at 100 degrees it boils much higher 140 or more and I've had no more problems since using it.
I called LTR Friday to get some parts for the upcoming GNCC season. Wanted to purchase the impeller, PV cover, case guard and the chain guide for my 06 EC250. Les said he was sold out of all of the items I wanted and did not plan on having any more made. He said the market just wasn't supporting the cost of production and maintaining the inventory. Bummer!!!!!
Anybody have an impeller and a PV cover for sale?????? I wound up ordering a TM Designworks chain guide.
Call around to the dealers. My brother saw some LTR stuff in stock at a shop in PA last fall, Shultz Cycle I believe.
Well make your own spacer. All you do is take the gasket and make a template on a half inchblank of steel.
new source
We have worked with Les for many years and we appreciate all he's done for GasGas. The last few months he's decided not to continue with some of the items and we have outsourced to a couple different machinists....those items and more are readily still available through your dealer and or retail outlet.
"those items and more are readily still available through your dealer
and or retail outlet."
ummm, ok. reading betwen the lines....
I will take that to mean I can call tomorrow and order
an alloy aftermarket hi-performance water pump impeller from
my dealer or GoFasters direct... It that correct?
Same great performance, same great design?
Do I need to have my dealer refer to a particular part number?
Thanks, Jeff
I now have 2 gg's and the guy i bought them
from called me and told me to come by he had a box for me... He was a gg dealer back in 00-02, my bikes are 00 and 01.it is all the old parts he had left over and never sold.. I have an extra impeller in that box if you still need one, I have them on both of my bikes. there are alot of extra parts i have not figured out what they are, but there is some stuff i have never seen....
pm me if you still need one. the one impeller is all that is ltr...
jay
You might tell your employees this. I just called and they said no impellers.
I need one myself. Anybody have an extra?
sent the last one i had to slocal...
sorry. there is supposedly some more gg parts I will get from the guy i bought mine from, but i have no idea what is in there or when I will get them..
Yep, got it. :)
One thing though. I must assume LTR made a design
change sometime during the time he was having
these made. The two of them I have, both in
LTR packaging, are different. One has a thin shim on
the back side. The instructions state you must use the
shim when mounting the impeller. The other one I have
does not have a shim, but, it has a 10mm, or so, hex
cast as a boss that the head of the pan head cap screw
mates against.
The two instructions sheets are the same with the exception
of the sentence that states you must use the shim on one
of them.
There is a slight difference in the casting marks too.
Thanks, Jeff
I did not remember a shim in the first one i put on either.....
I thought it was something I had forgotten when I put the one on my 300 a year ago.
