I brought a set of braces from go fasters and the brace seems about 10mm to long. My radiator seems a bit bent in places, but not too bad. should I bend the rad/tabs to fit, or cut down the brace/post.
If the brace is fully threaded in to the tab on the frame and the other end sticks out past the grommet in the rad more than a couple mm the rad is bent. It doesn't matter though, as the shroud now mounts to the brace not the rad.
