Mako 360
Does anyone have experience with mako 360 bar mount? What are your thoughts?
I haven't heard of those before. My instant thoughts are that I'd rather have a Twisted engineering handlebar.
And I do ;)
Jokes aside, if you feel the need for some flexibility, there are several options. Damping mounts like the PHDS systems often used on the orange bikes, Flexx bars, TE, and now Mako (another sort of damping mounts / clamps).
Dirt rider is quite pleased, I see: https://www.dirtrider.com/three-things-bar-mounts-review
I have ended up with the TE bars. I have used them for at least four years (>300 hours) and am very pleased. I haven't felt the urge to try something else. However, the Enduro FIM rules have something against composite bars. So if you are competing, I guess Mako is a safer bet.
I’ve tried PHDS, Twisted Eng, Flexx Bars, and now Mako 360. I will never ride without a Mako again. It puts all the other dampening systems to shame. You get full 360° dampening, lots of tuning options, MEGA vibration reduction, you can run ANY bar bend and ANY brand of bars you choose, and Lance and Lisa are fantastic people with excellent customer service.
If you really want to be happy, but the Pegs as well. I actually like the pegs more than the bar mounts.
I have a set of these going on this week. I ride with a group of local fast guys and they disagree on everything with one exception- the MAKO 360 mount. So I will probably have an update in the next week or so. Will also be testing my new RK-TEK head.
I?ve tried PHDS, Twisted Eng, Flexx Bars, and now Mako 360. I will never ride without a Mako again. It puts all the other dampening systems to shame. You get full 360° dampening, lots of tuning options, MEGA vibration reduction, you can run ANY bar bend and ANY brand of bars you choose, and Lance and Lisa are fantastic people with excellent customer service.
YES, to all the above.
Superb product with great improvement to cost ratio.
The only caveat being that you can't use the Mako as stock in the most forward position of the triple clamp with the mounts turned to put the the bars furthest forward because of interference with the top cap of the fork.
I spoke to Lance about this a couple weeks ago and he's aware. The lower mounts are a shared part to many machines and so few riders set their bikes up with the bars in that position it's rarely an issue that's ran into.
IF you need to set your bars up like that because you're 6' 7" tall or you're a recovering trials rider and don't want to lower your forks all the way in the clamps you could machine (or file or belt sand) 3-5mm off the outer edge of the mount and they'd clear.
Lance has my triple clamp (Xtrig) now and is working on the fix, should carry over to the stock triple. Hope to have it back this week.
He mentioned that the next batch of lower mounts that will be machined are changing design but also said there are quite a stock of current design to go through. I doubt it'll bother even a handful of people.
I put mine on this weekend and with the bars in the normal position and the furthest back hole the (stock position) the forks will still only fit to the top line in the triple clamps. Nothing a Dremel can?t fix, but it would?ve been much easier to fix this before mounting.
I have the Twisted Engineer bars and they do work but I think these Mako dampners may end up on my other ride . Thanks for sharing and let me know how they are working ?
It is a bit tedious with the way these mount up with a double threaded stud vs the previous model I had with a socket head cap screw. I'm not sure I like the idea of a double threaded stud. Seems like a lot of stress to put on the Aluminum threads of the bar mounts.
It seems an odd choice to use them being that they are probably 2-4x the price of a cap screw as well.
At this point if they're good enough for the NEGP and 6days GG teams I suppose they'll work ok for me. If I see any thread stretch when I tear down in a couple months prior to the start of the race season I will mill the mount holes out for a socket head cap screw.
And I do ;)
Jokes aside, if you feel the need for some flexibility, there are several options. Damping mounts lie the PHDS systems often used on the orange bikes, Flexx bars, TE, and now Mako (another sort of damping mounts / clamps).
You may want to correct Lie to Like, for a while i thought you were anti-damping mount bars lol
