I have an 05 MC250 with a stock Messico pipe with very few hours on it. I just noticed the other day it is barely weeping oil from one of the welded seams in the expansion chamber.
What is the best way to repair this, or should I even worry about it? I have access to MIG and TIG welders and am a fair welder when in practice, which is not now. The pipe appears to be plated with nickel. Should I try to weld this as is or sand the nickel away before welding? Will epoxy such as JB weld work or some other type glue?
Also, I changed the silencer on this pipe to a FMF Q that was made for another bike. It killed all the top end and gave me a ton of low end. I drilled the rivots and took out the spark arrestor and extended the stinger to the length of the outside can, which is about 2 or 3 inches longer than the stock Messico.
The power is back, but will the extra length change power characteristics over the shorter stock? The pipe now has a real throaty sound at lower RPMs, not quite as deep as a four stroke, or big bore.
Matt
Matt
