swazi_matt
Active member
Since your weight will have shifted forward from dragging the front brake and already loaded the front tire, the tire will bite as you gas it and turn. But, you need to hit the gas as you are letting off the brake, just as you start to "throw" the bars. (tight woods tree dodging)
Do it in "slow motion" first, to get the timing down.
My natural inclination is to slow down, turn, and gas it. That is not the fast way. It turns much better under power, when I slow down, gas it, and turn.
Let me know how it works for you.
Set up a figure8 track and work on getting your technique programmed into your muscle memory. As Graham Jarvis says you need to know slow to go fast (or something like that)
If you compare dirt biking with golf (or another sport where technique counts for more than talent/ fitness) you will note that they spend a lot of time around the putting green or driving range whereas most of us just want to head to the hills. If you can be dedicated and spend an hour doing technique drills for your cornering, balance wheeling etc you will get better and continue riding well into the balding grey years
