Hey guys my 2001 gas gas ec 200 used to be amazing on fuel until recently it?s just using way to much. The lads I ride with have KTM?s exc 300 by the time they?ve got half tank mines pretty much all gone what can I do to help this? Thanks guys
The seat is not easy to change on a PWK. You can clean up the seat by chucking up a Q-tip in a drill, dip it in tooth paste and "drill it" to clean up the brass seat surface.
My 01 EC250 was leaking fuel out the overflow vent. When I took the carb apart the float pin bores were so worn i could not get the float height set properly to set it. New carb was the fix
