The axle clamp offset.
I was struggling with the best way to measure the clamp offset. I thought about a plumb bob with the string on the side of the lower tube in a few spots. Then the plumb bob down through the axle hole . Mark a sheet of paper then mesure off that.
In the end I just traced both sides of the lower tubes, found the center and ran a straight line down past the axle hole. I then traced the axle hole, found the center and mesured the distance to my fork tube line.
Dont take it as gospel but seemend to be prety acurate.
45mm Zoke 35mm center of lower tube to center of axle
48mm kyb 32mm center of lower tube to center of axle
So the kyb is 3mm closer.
The yamaha tripple clamp offset (25mm) is 3mm more, than the GG offset (22mm) which should put the front wheel at the same spot as it was with the GG clamps and zoke forks.
I was worried about the kyb forks hitting the frame, if you look at the pic below you can see the spot on the frame were my 45mm zokes were hiting
Here is a picture with the forks and clamps on the bike. If you look close you can see the upper bearing nut. I have not mesured anything yet but the nut is thicker putting the bars higher , but also the spacing between the clamps might be more than the spacing with the GG clamps. So with the forks being the same length if the the same amount is exposed above the clamps with the both setups the kyb flush with the clamps could be the same as the zokes up in the clamps (sticking out the top). That will be my next investigation
Here you can see the upper portion of the tube hitting the frame. It looks lie a rubber fernco pipe coupling will protect it .
The lower clamp bolts get into the radiator plastic louvers a bit. Will trim them.
All that is left is get a front wheel and caliper. I see no reason to mess with a GG wheel. Much simpler just to convert.
After talking to a few tuners the other day I have decided to send the forks and shock to Drew Smith at WER.
Hopefully I will be riding it by the end of next week
ED
