In many cases I'd say the JD is not worth it, especially in the new carbs, but this is not one of them. I have over 50 needles and only run this one, it just works. The needle is sort of a cross between a single taper DDK and an N3EG. Its smoother than the N3EG though with good pull off the bottom. You can try working with the N3 while keeping your eyes open for a deal on a JD Blue. With all the SmartCarbs due to show up by May, there may be some available. BTW, JDBlue is the same needle in multiple kits, including the KTM 2stroke kits, so you have options.
