mountain thumper
i am stuck with a dilemma..
i have a couple hundred extra bux to put into my girl
its mostly stock, jetted, reeds, and lights are all i have done to it.
i came off an xr, and at times, wish i was still riding one.i hold on too tight, so sometimes when i stand up, come off a jump high in the front or hit a whooptie just right, i pin the throttle= very bad things..
thats why i went to a 4t in the first place. but then i rode an 03 with a lot of goodies, and i wanted that top end so i went back to 2t. want to make it as torquey as possible..
anywho i have questions about upgrade effects.
flywheel weights: how much does this affect the front end, i like to pull it up over washouts and small trees does it just slow it way down..
zstart: same here, can you still wheelie? when your clutch goes, do yo have to buy another zclutch, or just a clutch.
g2 throttle cam system: ive read a lot of good and some bad about these. i see how it would benifit my tendency to twist the throttle at the wrong time, and take a little bit of the hit off the bottom. but would it make the response dog out, i hate backing down hills
im looking at buying a couple things. im tossed between pv cover, gnarly pipe, ltr performance kit(with doma) g2 throttle or a hyde skid/pipe combo. btw anyone buy one of these for an 07 300? how long was the wait?
im tossed about ltr jets too. my bike was supposed to be jetted by the dealer(got it used), and included a lot of jets. but all of them, including the ones in the bike were the same sizes... what kind of difference is it, from stock to the ltr? the pic only shows one of each jet and a needle, dont you need several jets to adjust for elevation?
also my slide is a number 8, whats the difference? and how do i adjust the needle. mine has a bolt head on top of it, and i dont understand how to remove the needle to adjust the oring..
helpless n00b i know..
