MattR
Background Info:
I'm tweaking my jetting on my '07 EC250 for cold weather riding (20 to 30 degF). Since this is only my second ride on a "new-to-me" bike, I don't have any warm weather experience to compare it with.
The previous owner had the following jetting. This is what he ran in the warm weather.
Main = 172
Pilot = 45
Needle = LTR
Needle position = #2
Airscrew = 1 1/2 turns out
Slide = 6.5
For my ride last weekend when the temperature was 30 degF, here is what I had installed:
Main = 180
Pilot = 45
Needle position = #3
Airscrew = 1 turn out (initially), but changed this to 1 1/2 turns out.
Needle and Slide = same as before.
Ride characteristics:
It felt a bit rich off idle to 1/4 turn throttle, so I turned the airscrew out to 1 1/2 turns (too lean it up slightly). This felt like it cleaned up the bottom.
Around 1/2 throttle, it seemed to sputter like it was running too rich. Then, it would rev out fine from 3/4 to full throttle (so I think my main jet is fine).
Here's my question:
Is this sputter at 1/2 throttle a rich condition like I think it is???
Correct me if I'm wrong here, but I think changing the needle clip to the #2 notch would help. My thought is if it is running rich, then the #2 notch will dropped the needle and make it more lean.
What do you guys think???
Main = 172
Pilot = 45
Needle = LTR
Slide = 6.5
Main = 180
Pilot = 45
Here's my question:
