needle roller query
noobi
im about to do another top end rebuild.
id rather not get raped over the cost of the little end needle roller bearing again, it was 45NZD last time around
the manual says its a 18x22x22 bearing. the part number for a 125 is different than for the other bikes but the other bikes also use a 18x22x22 bearing.
are they the same or what?
im sure i can find a 18x22x22 caged needle roller bearing for less than $40
the problem is that if the part numbers are different im thinking its not a normal bearing :confused: :confused:
If the piston kit is YZ125, and the rod kit is YZ125, the bearing should be YZ125.
Nothing special about that bearing. My manual is not on this PC but I would not bet on GG part #s.
I'd bet the one in the bike now is fine, as long as the rod and piston pin are fine as well. I don't even bother with these anymore unless I'm doing the rod as well. Think about it, the rod surface is one race of the bearing, and your not swapping that, right? Of course you use the new pin as it comes with the piston.
piston pin, wrist pin, small end connecting rod bearing crossover
While there are several posts on this topic I could not find a complete answer on the crossover part number. I beleive the correct 18mm x 22mm x 22mm piston pin, wrist pin, small end connecting rod bearing is very common. The funny/sad thing is that none of the Honda shops in the Chicagoland area had this bearing in stock!
Oh well Wiseco sold me one for <$13 plus shipping.
Here are a few that should work.
Honda part number 91015-357-003
Wiseco Part#: 21.1303 or B1003
If you have faith in ebay auction details, these are other applications that may cross over too.
ARCTIC CAT (SUZUKI SPIRIT)
Bearcat 440 I II 1995 1996 1997 1998 1999 2000
Jag 440 1987 1988 1989 1990 1991 1992 1993
Jag 440 1994 1995 1996 1997 1998 1999
Jag 440 Z 1993 1994
Jag 4000 1981 1985 1986
Jag AFS 1989 1990 1991 1992 1993
Panther 440 esr 1993 1998 1999 2000 2001
Panther 440 FC 1980 1981 1984 1989 1990
Super Jag 1987 1988 1989 1990 1991 1992
Trail Cat 4000 1980 1981
Z 440 1995 1996 1997 1998
ZR 440 1996 1997
ZR 440 1998 (consumer model)
HONDA
ATAC 1984 1985
ATC 250 R 1981 1982 1983 1984 1985 1986
CR 250 1984 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994
CR 250 1995 1996 1997 1998 1999 2000 2001 2002 2003 2004
CR 250 R 1978 1979 1980 1981 1982 1983
FL 250 Odyssey thru 1984
FL 350 Odyssey 1985
MT 250 1975 1976 1977
MR 250 1975 1976 1977
TRX 250 R Fourtrax 1986
TRX 250 R Fourtrax 1987 1988 1989
HUSQVARNA (2 Cycle)
CR 250 1974 1975 1976 1977 1978 1979 1980 1981 1982
CR 250 1983 1984 1999 2000 2001 2002 2003 2004
WR 250 1974 1975 1976 1977 1978 1979 1980 1981 1982
WR 250 1983 1984 1999 2000 2001 2002 2003 2004
WXE 250 1992 1993 1994 1995 1996
WXC 250 1992 1993 1994 1995 1996
XR 250 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984
SKI DOO (ROTAX)
Alpine 1970 1971
Alpine 500 1983 1984 1985 1986 1987 1994
Alpine II 1988 1989 1990 1991
Blizzard 5500 MX 1979 1980 1981 1982 1983 1984
Blizzard 9700 1983 1984
Cheyenne 1989 1990 1991
Citation 4500 E SS 1980 1981 1982 1983
Elite 450 LC 1978 1979 1980 1981 1982
Elite 464 LC 1978 1979 1980 1981 1982
Escapade 1987 1988 1989
Everest 340 1977 1978 1979
Everest 1974 1975 1976 1977 1978 1979
Everest 444 LC 1978 1979 1980 1981 1982 1983
Everest 500 1980 1981 1982 1983
Formula Dlx 380 1999 2000 2001
Formula Dlx 500 FC 1999 2000 2001
Formula Dlx 583 1997 1998 1999
Formula Mach I XTC 1989 1990 1991 1992
Formula MX LT XTC SP SS 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994 1995
Formula MX Z 1993 1994
Formula Plus XTC 1985 1986 1987 1988 1989 1990 1991 1992 1993
Formula Plus E X II EFI 1992 1993
Formula S SE 1995 1996 1998 1999 2000
Formula SL 1995 1996 1997 1998 1999
Formula ST 1994
Formula STX STX2 1994 1995 1996
Formula Z 1994 1995 1996 1997 1998 1999
Grand Touring 380 FC 2001 2002 2003
Grand Touring 500 FC 2001 2002
Grand Touring 580 XTC 1994 1995 1996 1997 1998 1999
Grand Touring 583 XTC 1994 1995 1996 1997 1998 1999
GSX 380FC 2005 2006
GTX 380FC 2005 2006
Legend 380 FC 2002 2003 2004
Legend GT 380 FC 2004
Legend 500 FC 2002
MX Z 380 FC 2001 2002 2003 2004 2005 2006
MX Z 500 FC 2001 2002
MX Z 583 1997 1998
Nordik 60 1987 1988 1989 1990 1991
Nordic 377 1981 1982 1983 1984
Nordic 399 1970 1971
Olympique 1970 1971 1972 1973
Olympique Plus 1977
Olympique 300 1971 1972 1973 1974 1975 1976 1977
Olympique 335 1969 1970 1971 1972
Olympique 340 1975 1976 1977 1978 1979
Safari 377 E 1984 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994
Safari 503 R 1988
Safari GLX 1990 1991
Safari Grand Luxe LC 1985 1986 1987
Safari L LE 1990 1991 1992 1993
Safari LC 1991
Saga 1989
Scout E 1989 1990 1991 1992
Skandic II R 1992
Skandic 335 1970 1971 1972 1973
Skandic 377 377R 1982 1983 1984 1985 1986 1987 1988
Skandic 377 377R 1989 1990 1991 1992 1993 1994
Skandic 380 1998 1999 2000
Skandic 500 1987 1988 1989 1990 1991 1992 1993
Skandic 500 1994 1997 1998 1999 2000 2001 2002
Skandic 503 1987 1988 1989 1990 1991 1992 1993
Skandic 503 1994 1997 1998 1999 2000 2001 2002
Skandic Sport SWT WT 1998 1999 2000 2001 2002 2003
Stratos 1987 1988
Summit 470 1994
Summit 500 FC 2001 2002
Summit 583 1994 1995 1996 1997 1998
SS25 1984
TNT 340 1972 1973 1974
TNT FC 1975 1976
TNT 340 RV FA 1976 1977 1978
TNT 399 1969
TNT 440 FC 1974 1975 1976 1977 1978
Touring 380 FC E LT 1996 1997 1998 1999 2000 2001
Touring 500 FC SLE 1995 1996 1997 1998 1999 2000 2001 2002
Tundra R 2005
Valmont 399 1971
Voyageur 1989
SUZUKI (2 Cycle)
RM 250 1981
PE 250 1981
YAMAHA
YZ 250 1976 1977 1978 1979 1980 1981 1982 1999 2000 2001 2002
YZ 250 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012
DT2 3 MX IT 250 Enduro 1980
IT 250 1980 1981 1982
GP 292 1972 1973 1974 1975
DT MX 400 1975 1976 1977 1978
IT 400 1977 1978
YZ 400 1977 1978
EX 440 1976 1977 1978 1979 1980 1981
GP 433 1975 1976 1977 1978
GP 440 1975 1976 1977 1978
PR 440 1976 1977
STX 440 1976 1977
SS 440 1980 1981 1982 1983 1984 1985
PZ 480 Phazer all 1984 1985 1986 1987 1988 1989 1990 1991
PZ 480 Phazer all 1992 1993 1994 1995 1996 1997 1998 1999
PZ 500 Dlx Mtn Lite 1999 2000 2001
VT 480 GTS XL Venture 1991 1992 1993 1994 1995 1996 1997 1998 1999
VT 500 XL Venture 2000
piston pin bearing
strange, on my EC125?05 the piston pin is 15mm thick and the rod is 20mm.
It has a w?ssner piston kit.
anyone know what the actual standard dimension is on the 125?
on the parts list it says:
12 RODAMIENTO 18X22X22 PIE BIELA / ROD BEARING
ME120116035
if you look at the picture it shows the complete rod with both upper and lower bearings
