Hey Guys,
Does somebody know the Code and manufacturer of the lower main Crank needle bearing for a 2018 GP300?(See picture)I want to rebuild the crankshaft myself and don't need the crank and main shaft contained in the set.
Thank you guys!
Built from the strongest and most dependable alloys available today Includes crank pin, big-end bearing, small-end bearing, and thrust washers Fits: 2021-2024 Rieju MR 250-300 1997-2019 GasGas EC/XC 250-300
motocenteraz.com
Not sure why you'd rebuild a crank without a rod/pin change.
