Clutch was starting to slip in my 11 300 ec r so I replaced it with a Barnett dirt digger clutch kit ( friction plates, steel plates and springs ). Everything went together as it should, clutch pull is noticeably firmer but I am able to get the power to the ground again.
Problem is now the bike is stalling a lot when I am under hard braking with clutch lever pulled in. I have the lever properly adjusted (does not stall or surge when shifting from neutral to first).
I can feel the bike pulling when I have the lever pulled in and I am slowing down for a obstacle, hill or turn.
Any other ideas aside from lever adjustment?
