New Gasgas owner - Parts Question
smallpuffydog
Bronze Level Site Supporter
Is there someplace I can go to get a full list of crossover parts for my 2007 300?
I am guessing that there is crossover for the following items, but its very hard to find someone local with the knowledge to help:
- Clutch and brake levers.
- Shifter lever.
- Air filter.
- Clutch plates.
- Bar clamps.
- Sprokets?
Sorry if I am overlooking it on this site.
Thank you,
Matthew
- Clutch and brake levers. moose has them
- Shifter lever. no known QUALITY replacement
- Air filter. cr250r
- Clutch plates. cr250r - clutch mod needed.
- Bar clamps. haven't checked.
- Sprokets? modern husky 4 stroke for rear, none for front?
Matthew did you see the "patrs crossover" section on this site. It doesn't answer all you questions but it may help with a few of them.
I did see the parts crossover list that has been posted.
I thought for sure that some other manufactures levers might fit as well (like Honda, KTM or Husky). But no luck, huh?
the moose levers are like $15.00...
I guess what I am getting at is that the Parts Unlimited catalog that my local shop has doesn't even list GasGas as a mfg. So if I know what the crossover might be I could help them.
I guess that I will go on the Moose website and look for a part number.
my local shop just scanned catalogs for a moment and found them...
moose #1CDGS17 clutch lever
i can't find the brake lever - but most honda 2 strokes 'should' fit, i know i've switched it to one that has a bigger offset (closer to the bar)... i'm sure it was less than $20.. i'd remember if i had to pay dearly for it...
Thank you.
'07+ filter is different than older bikes and CR250 filter WILL NOT fit. Hammerhead make a nice shift lever with different offset tips available. I would still rather have a steel one though for durability. BRP should have bar clamps.
