New plastics, grafix, and numberplate 2010
john01
Hey guys my son just installed the new 2011 front fender, numberplate, and a PG grafix kit he designed on his 2010 GG 300. It turned out very well IMO. Anyone care to send me a PM and put the pics up for me? I can email them to you through the Kodak "not so Easy Share" but can't post them on fourms. Thanks, John
Sign up for Photobucket and put them there. Then you can link your post to those pictures.
Thanks Daniel thats a heck of a lot more than I can do with pics. At least the guy's that want to see a GG with a numberplate can do so.
Looks very good.
This is the front numberplate set up GoFasters is offering, correct?
Any pics of supplied brackets and mounting?
Does the bottom of the number plate sit in the headlight shells front stock fender mount (Hole)?
Wondering if it will work for my needs with an e start or if fabricating up my own brackets would better suit me.
Thanks,
Roscoe
Thanks. Yes it's the GF'ers front numberplate hardware. It's very well made quality part. On his 2010 with the 2011 front fender we had to use a slightly longer bolt to attach the flat bracket to the square tubing section of the kit. Other than that it was all included. The Honda numberplate does fit into a plastic supplied bracket holder that it all bolts to. I am sure if GG made a numberplate it would fit the contours better but overall it works for us. I will get some close up pics for you in the morning.
The front numberplate bracket sysyem was $42.00. The 2011 front fender, Honda 09 numberplate, fork guards (not installed yet), side panels/rear fender, and 2 rad. shrouds all in white cost right at $240.00.
Oh, I think the PG grafix with the grip deal was $199.00. They have a grippy surface on the decals that go on the rad. shrouds and side panels. Looks like they will hold up very well. Hey do the 2011 GG bikes come with the grip grapix?
Looks fantastic John !!
the 2011's have some sort of textured graphics and they are quite HD but I do not know makes them....
The side panels where it says EC300 have a textured surface to them. They are actually quite nice. Everything else is smooth.
EDIT: I just noticed that there is a little bit of the textured graphics on the the headlight. I like that stuff.
Number Plate
We have come out with a Number Plate Bracket for all 2004 and newer GasGas bikes 200/250/300. This includes a high grade aluminum brackets with a white number plate. The total cost is $42 for the bracket that fits both E-Start and all other models. The kit allows for the bracket to fit the ignition for the E-Starts. This will fit older bikes nicely.
Excellent! I will order one Monday.
Just want to be clear.
Number plate is 2009 Honda CRF and up number plate?
Want to make sure I order the right number plate background to match the PG backgrounds I have already.
Thanks,
Roscoe
Thanks,
Roscoe
Yes, that is correct. It is tough to find that Honda number plate that is in stock. Anywhere in the US. The kit will fit Acerbis & UFO but not the Cycra Stadium plate.
