Hi,
I've removed the OEM switch gear and connected a KDX kill switch. I did this by cutting the (hopefully) correct 2 wires behind the headlight unit and using a connector block to join them to the new kill switch.
Assuming I've got the right wires, my question is... Will this cause me any problems? Do I need to waterproof the connector block (I was thinking silicone with electrical tape around it) or should I use an alternative method to connect the wires (a mate suggested soldering and shrink wrap)?
Thanks in advance
Ross
Thanks in advance
Ross
