Ohlins shock shim stack
Compression
520-40 (10x)
610-34
1115-30
520-40 (3x)
525-38
525-36
525-34
520-32
520-30
520-28
520-26
530-22 (2x)
Rebound
520-36 (5x)
1115-28
525-36
525-34
525-32
530-30
530-28
530-26
530-25
530-24
530-23
530-22
610 = .10mm
1115 = .15mm
520 = .20mm
525 = .25mm
530 = .30mm
Stock stacks for 06-10 ... I have the stock stacks out of my 2010/11 888 shock as well.. I'll post them below.
2010 Euro / 2011 Stock stacks, as pulled down.
Compression
40 0.2
40 0.2
40 0.2
40 0.2
40 0.2
40 0.2
40 0.2
40 0.2
40 0.2
40 0.2
34 0.1
30 0.15
40 0.2
38 0.2
36 0.2
34 0.2
32 0.2
30 0.2
28 0.2
25 0.2
22 0.2
19 0.2
37 4
Rebound
36 0.2
36 0.2
36 0.2
36 0.2
36 0.2
36 0.2
36 0.2
28 0.15
36 0.3
34 0.3
32 0.3
30 0.25
28 0.25
26 0.25
24 0.25
22 0.25
30 3
interesting jake after a shit month since 6 of my bikes were stolen iv had to jump back on the 05 250 forgot how good the 45 mar 888 ohlins work in the woods and how light the 05 rides to my 013 300 and the 018 300 i had a long ride on any way back to the 05 did the linkage change from 05 to 011 as im thinking of updating the 05 to 011 valving thanks robin
Does this look right to everyone? Can't tell what the red bits are and do? I have an older shock that doesn't have them, any ideas?
Had a good look about, and basically the shock has been lowered... Wow. I can find the washers online and they appear to be racetech, but there is an aluminium but under that which I can't find in any lowering kits, and is not there on my spare shock so I've taken out of, any idea where there come from?
I can't believe I've had this bike 7 years and not known it's been lowered...
whats the centre to centre length of the shock iv got the ohlins dater sheet for 05 and 06 the red spacers look ohlins
Geeeze she's dirty!!
Ohlins use plastic spacers to set the shock lengths. Completely normal.
Here's a pic I snapped when I serviced a mates 09 888.
P1020334_zpsuiugrosa.jpg~original
These are the shim stacks I've found and what I've done.
2006 - this was revalved by a very renowned tuner in the UK, needless to say it was terrible, very harsh spiking over square edges, so I've removed the 2 stage, added another face shim, and put 2 smaller base shims in for firmer low speed and softer high speed.
Comp
40.2
40.2
40.2
40.2
40.2
40.2
30.1 ** + 40.2
26.15 **
38.25
36.25
34.25
32.2
30.2
28.2
26.2
23.2
21.2
+20.2
+18.2
Reb
36.2
36.2
36.2
36.2
26.15
36.2
34.25
32.3
30.3
30.15
28.3
26.3
25.3
24.3
23.3
Spare rear shock from earlier model with no HSC adjuster
Rebound
36.2
36.2
36.2
36.2
36.2
34.25
32.25
30.25
28.25
26.25
23.25
22.25
21.25
20.25
19.3
19.3
Comp
40.2
40.2
40.2
40.2
40.2
40.2
40.2
21.15
38.2
36.2
34.2
32.2
30.2
28.2
26.2
23.2
20.2
18.2
