Ohlins TTX Cartridges
orangezuk
I ran them in my 08 KTM 200XC
approx 15 hours since last service, .47 fork springs, valved for off road by Coppersmith.
I wish they fit my 125, but they don't.
$650 shipped anywhere in the lower 48
205.22two.768six
dirtbikesupply at gmail dot com
205.22two.768six
What type / size forks do these work in?
The should fit 08-09 WP closed cartridge forks (XC/SX) and will fit the open cartridge forks (EXC/XC-W) with a base valve adapter that is available from any Ohlins tuner. I was told that would fit in the Sachs 48mm forks with the same adapter (not 100% sure on this) and they should fit the later model 48mm KYB/Showa forks.
You need the adapters plus the cartridges need to be shortened to fit the Sachs 48mm tubes.
It was easier for me to just use the complete WP forks on the Gasser.
