brains
The 05 250 had a strange fault (see - electrical - fix for no spark), so I thought it was about time to check on the rings......
Factory spec on MAX wear/ring gap = 0.7mm
Mine = 6mm
Just go's to show that a GG will run forever, it was still running fine with these pieces of wire (rings) around the piston.
Mine = 6mm
