Looking for another set of wheels for my 2012 EC300r. Any options? Just trying to find a used set to utilize different tires and different gearing. Any help is greatly appreciated. Thanx.
Any Gas Gas wheels will work, but the wheel bearings changed arty some point. It's alright though, because the outside diameter remains the same, and you can just put the 2010 bearings in the old wheels. I had a set of 2001 wheels on my 2008. Had to swap the bearings. I liked the rounded wheel.
When I put the wheel bearings in the front I had a large distance from the edge down to the bearing. So when I put the seals on with the spacer the seal was 1/2 inch away from the bearing. Its that ok to do this?
