Mine has been in the same spot too, in a box on the shelf! Seriously, you don't need it, and its one more thing to fail. The one on my '03 had a hole rubbed halfway through it by the headlight wiring before I removed it Its not an overflow tank, its an expansion tank. You still can loose fluid from the cap releasing. Replace it with a length of hose and leave a 10mm air gap over the coolant level and your fine.
