Richardcranium
Parts for sale Make offer
My wife has given me an ultimatum, it's her or all of my stuff. Well as much as I would like to get rid of her, I do need her around to do all of the household chores and take care of the kids. So, I am getting rid of all of my parts. I am starting this list and will add to it as I progress with the uncovering of parts. So here it goes' all parts are for 2003 bikes, sorry gentlemen. These parts are in Misery, I mean Missouri. Thanks
I will entertain offers at this time.
250/300 stator cover $20
1 Skid plates,great shape $10
1 front axle $15
2 rear axles $15 each
450 fuel tank with pump and cap $100
1 rear brake caliper and master cylinder $125
1-03 450 FSE cases w/bearing $100
1- 03 450 complete bottom end $250
3- 450 Throttle bodies $30 each
1- 03 450 Stator mounted on cover $75
1- 03 450 Sprag clutch mounted on Flywheel $100
1 450 airbox with inner fender, new $35
1- right side case clutch ,water pump 2 stroke part # ME25632001 $25
1- 02 125cc complete engine with pipe, electronics, and radiators $400
1-outer clutch cover part #ME250332002 $20
1-450 inner clutch cover part # MFS400132001 $25
1- Domino throttle $15
1-450 dash/computer with keys, slight rash $45
1 450 fuel pump complete $75
1- 450 starter $50
1- headlight new $40 part# BE250220024
1- Ohlins rear shock $125
1- 450 Cylinder and piston good $125
1-450 Cylinder and piston 2 hours run time $175
1-shift lever part # ME25936026 $30
1-rear shock linkage $50
1- set of dog bones $20 122mm
1 front brake resevoir for the SM450 $20
1 set of powervalve covers for the 300 $30 (right and left)
2- 45t sprocket specialist new $20 each
1- handlebar set $25
1- intake and exhaust cams 450 $75
3-450 Stator gaskets
2- 450 head gaskets
1 450 clutch cover gasket
1- 450 exhaust donut
9 sets of 300 head o-rings sold 3, 6 left
1- set of pegs good shape $25
1- LTR Impeller used $40
1- New Black plastic impeller $15
2- used black plastic impeller $10
FSE 450 Shift cam and Forks $50
Speedometer wire/cable $20
2 FSE 450 valve cover gaskets $10 each
1 set of washer gakets for the FSE Valve cover bolts $10
I should have other parts later as I dig them out. Shipping is extra, Thanks
1 front axle $15
1- 450 starter $50
2- 450 head gaskets
