Nitrogen is way safer as it does not expand like air. That is what my brother uses.
What? It expands just like air.
I think a bigger issue with using air is not so much the unideal expansion, but the combustibility of the compressed oxygen in air.
There's a reason you avoid compressing gaseous oxygen.
O2 isn't combustible. Regular air is 78% nitrogen. 21% Oxygen and trace gases.
Take a look at someone who has popped out pipes. 30 psi isn't much, only 3 atm.
Technically its the oxidant. The steel pipe is the fuel.
Still incredibly dangerous stuff. You would probably get away with air, as the nitrogen would act as a suppressant, but using nitrogen instead of air is certainly safer.
30psi gauge is 2 atmospheres. There was mention of 80-100psi earlier in the thread.
