Polisport led headlight gasgas ec 125
stefaneo
Hi,
I'm new here, also a new rider, bought my first bike, gasgas ec 125 2002, back in may and I've done a lot of work on it since. Planning a supermoto conversion when I get the chance.
I wanted to buy a polisport e blaze, to go with my 2011 restyling kit, but i'm not sure if it will work properly. On the box it says that it works with both ac and dc 12v (in the specs it says 13.2v?), also that it requires 7.3W for low beams and 14.7W for high beam.
I don't really care about flickering or if i have to do a couple connectors but I fear that the lights won't turn on or that I will fry them (different voltage when accelerating? I don't really know).
The bike wiring wise is stock so i do not have a battery or any aftermarket wiring loom.
I appreciate any suggestion, thank you in advance.
As long as you have the regulator in place, I think it will work. The regulator should ensure that the AC voltage doesn't go too high.
Thank you, as soon as i get the chance I will check for it but i'm pretty sure its there. At the moment the bike is missing a few things so i can't start it to check wattage, but i do have a multimeter, so I guess if that's ok too there shouldn't be any issues.
