Hi, I recently Bought a 2005 EC 300, when I bought it the power was what I would call ordinary at Low to mid revs and it would not rev out at all. So First port of call was Clean out Carby and New Jets and Needle( Old Pilot was blocked) checked the reeds while the Carby was off and they looked brand New. Started it up ran a little better of the bottom but still no top. Because it was Rattling like Crazy as well, I pulled the Pipe Off Replaced the Missing Orings ( Looked inside Has New Piston in Bike, No carbon buildup at all) and pulled the power valve cover to check the Common Rattle caused by the lack of Spring tension, it needed adjustment, ordered Gasket did that, while the bike was on its side I noticed that operating the powervalve caused the powervalve to close not open( working in Reverse).
So now to my ? can you reseat (flip it 180 Deg) the back actuater pin without pulling the barrel and does the inside clutch cover have to come of again?
Thanks in advance
Alan
Thanks in advance
Alan
