Powervalve Action
Jakobi
Hi everyone,
Looking for a quick reply. I've got the cylinder off the EC300 and cleaning it up for a fresh top end. I had disconnected the actuator arm from the powervalve assembly and removed making sure the arm was not lifted. It remains as it should as far as I can tell.
Now moving the power valve in the clinder off the bike, it appears the range of movement is only about the lower half, if I move the valve higher open it locks, wont return back down, and has to be wound right over to closed again. Is this normal? or should the valve be able to open and return, even outside its normal working area. Just want to make sure its not binding.
If I want to remove it how do I? I have removed the 2 locking bolts on each side. I assume these will have to go in, undo the center allen key, then release the 2 retaining ones.
Thanks in advance, Jake
