Bought the bike awhile back and it was missing wen I bought it but had been sitting up not used for about 2 years so I blamed a dirty carb or spark plug. I stripped the carb and found water in it so assumed I found the problem I also cleaned the air filter and put a new spark plug in and changed the gear oil but the bike has got worse to the extent it won't rev past half open all the time it behaves like it running on a fouled plug and won't rev out clean and bogs down. The bike has a new piston and rings which were done before I bought it and were just run in. Has anyone had this problem or shed any light on it? I was thinkin power valve problem or not set right with the cylinder bein off doin the piston but they seem closed wen the bikes not running. Or could it b a timing issue even tho it shouldn't have been touched with doin the top end? I've also checked the reeds and they seem good and its fresh fuel in the bike. Any help much appreciated.
