hello
Im in the middle of swapping the rear wheel bearings, I tried to make a note of everything as I was taking it apart so it will all go back together properly
only one thing Im not sure on, when the collar came out (the bit the axle goes through that sits between the bearings) I saw it has groves at one end but not the other but as this fell out during the bearing removal im not sure what end the groves were at so does it matter?
thanks
si
thanks
si
