Hey all, hope someone can put my mind to rest.
My 07 FSR has a habit of loosing coolant.
I suspect it is the head gasket.
Symptoms:
I have had the thermo fan fitted as I thought the fluid was disappearing down the overflow through the radiator cap. (KTM one fitted)
Questions for you fellow FSE-FSR riders:
I should probably take some video to help explain it.
My back pack is getting a bit heavy now with the 1.25L of reserve fuel, 600mm of spare coolant, 2L of camelpak and tools!
Any help appreciated.
Symptoms:
- Looses fluid. (200mm aprox per ride)
- System stays presurised for a few days, even when cooled down to stone cold.
- The fluid in reservoir behind the head-stem goes white frothy when you rev the bike. But it does not stay frothy when it quickly settles (eg No oil in there)
- Does everyones fluid go frothy when you rev the engine? (cooling fluid that is! )
- Anyone fitted a boil over reservoir LIKE THIS to catch the lost fluid and will it return to the radiator when cool?
- Can a gaskit be blown where it forces air into the cooling system but not loose it all the other way?
