I'm still missing something. I have a clean carb (I just did it last weekend, and I am thorough), I have fresh gas, no ethanol, yet my bike will not run correctly until about 140. Of hundreds of engines of all kinds I've come across in my life, they all act in a similar matter
I don't think oil plays much a part of cars engine temperature. You can always use thinner oil. Back in the day of 160 thermostats, leaded gas, and carburetors, cars were lucky to make it 100 thousand miles, and required constant maintenance. Plus you had 10w oil, 20w oil, etc. With a 5w-30, you can cover a much larger temperature range. Now with 195 thermostats, and fuel injection, I have yet to see an engine honestly wear out. People blow them up, sure, but its always by abuse.
I'm not sure why this turned into a thread about how 2 strokes run ice cold. The fact is engineers designed the engine to run at a certain temperature, and I guarantee it isn't 120F. It has little to do with oil, and everything to do with tolerances, especially the piston and cylinder. I will lay money you do more damage running an engine hard at 120F than at 240F.
So with that, I will no longer respond to this thread unless its about thermostat housings. I'm simply too boneheaded to listen to more.
