Rear Brake Lever?
StuJohnson
So there is a thread about Hammer Head making a shifter for our GG's. What about brake lever?
I am not a fan of the OEM how it tucks behind frame -- very flimsy. Plus I have the Rekluse AL clutch cover (which sticks out further) and puts the brake literally right next to cover.
To me it just appears they have used a generic picture in their listing. The part number will probably relate to the stock 2012/13 brake pedal (that tucks behind the frame). The picture is clearly to suit an 01-11.
Good catch....I knew all a long. Just testing you to see if you would catch my mistake..... ;-)
:D
No idea re the hammer head either. In regards to the 2011 levers mine has been pretty reliable. Its just the rear bushing that flogs out and causes the whole pedal to get sloppy. Not sure if this is the case with the 2012 models too. I know that when mine was flogged out the pedal woul easily touch the clutch case though. Replacing it with a hardened one from checkpointoffroad saw the pedal move back out where it was meant to be and feel much better again.
