Rear Brake pedal spring..where does it connect?
JAD
Hi all, my brake pedal return spring is missing and I cannot for the life of me work out where the new one should fit. The brake pedal end is obvious but where do I attach the other end? The parts diagram is no help....
Thanks in advance...
It has been a while since I seen an 07 but is there a hole in the tube surrounding the swing arm pivot bolt in the frame?
Thats what I thought but I cannot see one.... I shall clean the area, get a torch and my specs and have a closer look!
Thanks..
Edit, having cleared away some muck it appears to just hook over a small fillet on the frame... seems to work anyway.
