Rear shock linkage bearing removal
brider
I have an '03 EC 300. The bellcrank part of the rear shock linkage has a frozen bearing in the center pivot (there are (2) needle bearings in the housing), is the method to remove one of these needle-bearings to use a small hooked puller to grab the inner race and pull it out? Can't see any other way, and driving either bearing out by pressing both thru one side seems like a bad method, especially if one bearing is still good.
Please advise.
In that situation I use a blind bearing puller and sometimes a little heat on the knuckle.
Vice. Small socket to drive both through on one side, big socket for it to fall into on the other. Replace both, don't cheap out.
Heat first.
Heat first.
Small socket/big socket aspect confuses me, seems like a single driver just undersize of the bore is what you want. This method seems crude, but effective if replacing both. May go this route if the internal puller I ordered doesn't work.
Where is the bearing going to go if the linkage is on the bench? Hence the large socket to push the bearing into. Personally I use a vice vs. brute force
