Rear Sprocket crossover
Almost all late model. That Husky WR250 should have the same rear sproket. The JT rear is JTR822
I put a gasgas rear 52t on my 2010 husky 250F direct bolt on,pretty sure like eff said,they are all the same from 98? on up
Great! I'm going to put a 51 or 52 Ironman on my 200 along with a Pirelli MT 43 with a tubliss set up plus a new chain and turn it into a tractor. At least that is my brilliant idea of the week.
Been using Husky rear sprockets for years. Late model years bolt right up. Iron Man, AFAM no problem. I run a 51 tooth on my rear of my 200.
Good Luck
No, but a KTM rear rotor is. Rotor bolt holes and OD the same with a mm or so larger ID but makes no difference. I have used them.
A trials tire has a much larger outside diameter which makes your overall gearing higher so you might want to go with the larger sprocket to compensate. Also trials tires are enough bigger that they can eat up your rear shock protector flap unless you make the chain 2 links longer.
A 91-93 Suzuki DR250S also uses the same rear sprocket but it must be the "s" model, the DR250 is different.
+1 I found that out myself when i went to trials tire with stock rear, I wondered where all my low power went to until I did the math. In my case my old S-12 @ 130/80/18 was 81" in circumference and the X-11 Trials @ 4.00x18 was 83" in circumference. Not a lot but did make a noticeable difference. (& mine is a 250). I run 13/51 gearing now & at times think I could stand a 52 or 53 even
That's good to know Fred, I think I'll go with a 52 or 53 since my 200 won't have as much down low as your 250. It's those leaf covered marbles at Mary's place that's forcing me to do this. See what you got me into.
'99 EXC rear rotor I'm sure of, so whatever years retain the same rotor pattern/size, which I suspect are most late models.
240mm (4.5mm thickness) Rear Rotor fits following models:
Gas Gas
125 EC Rear 98-07
125 MC Rear 03-05
200 EC Rear 99-07
200 Hobby Rear 07
250 EC Rear 96-07
250 MC Rear 96-06
300 EC Rear 99-07
300 MC Rear 96-06
400 EC FSE Rear 01-03
400 Pampera Rear 06-07
450 EC FSE Rear 03-06
450 EC FSR Rear 07
Husaberg
FE 400 Rear 00-03
FE 400 E Rear 01-03
FS 400 C Rear 01-03
FS 400 E Rear 01-03
FS 450 C Rear 03-05
FS 450 E Rear 03-05
FC 501 (4 Speed)Rear 99-03
FE 501 E Rear 99-04
FE 501 S Rear 99-04
FC 600 (4 Speed)Rear 99-03
FE 600 Rear 99-03
FE 600 E Rear 99-02
FE 650 E Rear 01-05
FS 650 C Rear 01-05
FS 650 E Rear 01-05
KTM
125 EXC Rear 00-07
125 GS Rear 93-97
125 MX Rear 89-91
125 MX Rear 92
125 SX Rear 00-08
125 SX Rear 93-97
144 SX Rear 08
200 EXC Rear 00-08
200 SX Rear 03-07
250 EXC Rear 00-08
250 EXC-F Rear 06-07
250 GS Rear 93-97
250 MX Rear 89-92
250 SX Rear 00-08
250 SX-F Rear 06-07
300 EXC Rear 00-08
300 GS Rear 91-95
300 MX Rear 91-92
300 SX Rear 00-02
300 SX Rear 03-06
350 GS Rear 93-
380 EXC Rear 98-99
380 SX Rear 98-99
400 EXC Rear 94-05
450 EXC Rear 03-07
450 SMR Rear 05-07
450 SX-F Rear 03-07
500 MX Rear 89-91
500 MX Rear 92
500 SX Rear 93-95
505 SX-F Rear 07
520 EXC Rear 00-02
520 SX Rear 00-02
525 EXC Rear 03-07
525 MXC Desert Racing Rear 06-07
525 SMR Rear 05
525 SX Rear 03-06
540 SXC Rear 99-00
560 SMR Rear 06-07
600 GS Rear 93-
600 LC4 Enduro Rear 91-92
600 LC4 MX Rear 90-92
620 Adventure Rear 97
620 Duke Rear 95-98
620 SC Supermoto Rear 00-01
Pretty much all KTMs and husabergs
