I had some other threads regarding my woes with my 2014 300.
I have coolant mixing with the oil in the crankcase. There seems to be no oil in the coolant though.
This is the second time this has happened. The first time, I rebuilt the water pump assembly with a new kit from Halls and that did the trick for about 10-15 hours. I now just found some coolant mixed in with my oil again and of course was down a few ounces of coolant in the radiator. This time it wasn't a full release of fluid as before, so not as much of a mess.
I am very concerned because the continued release of water into the crankcase is going to cause rust to bearings and clutch components.
Anybody know what is going on here? Just as a note I replaced all the gaskets with new gaskets when doing all the work.
