Reed Installation
papa_j
When re-mounting the reed block is there any sealant I should use? Should I do a leak down test after?
Thanks.
Reed install
Are you using the gaskets? there should be two gaskets. if you dont have the gaskets then I would use sealant. But next time removing the reeds will be more
of a clean up.
