(F5)
So we're pulling apart a mate's 07 EC300 last night. Done a bunch of hours, but probably less than mine I did a few months back.
Piston didn't look that worn, but it was a different make to the one I'd pulled out of mine. Very similar but
1. had black coating on some of the areas with silver (unplated) border
2. ribs under crown different
3. skirt was finished differently on the inside.
Otherwise it looked real damm close. I assume one of them was a Vertex
Mine was considerable more worn. Neither was a Woosner (which is what I put back in). No evidence it had been apart before.
ok so back to the queer part. Mine had worn rings, the closed end gap was like 1mm. Std for the 300 is 0.5-0.8mm
So slotted his in a reasonable ways. . . 0.3mm! Hells teeth!
I would have though being that tight they would have bound on each end & bulged the ring into the ex port. Can't see any scraping damage at all.
This makes a bit of a mockery of the ring end finishing I've done on other bikes. Who else has seen such close fitment on their GGs?
Surprised that it is so tight & not worn for the time he has put on it. Looked a very low hour bike when he got it.
