I sure hope someone can help me with this one. So I bought a 2000 xc250 frame and was given stock forks and clamps which I fitted and all was good.
I also got a set of Showa forks off an RM with new steering head bearings and triple clamps so I assumed it would be a straight swap over but when I removed all of the stock parts yesterday and went to install the bearings and races fit but the headtube length appears to be longer than the Suzuki so the lower set of threads on the stem land in the upper bearing.
Please advise if you have a solution. The upper triple clamp nut is not strong enough to hold it all together is it?
Appreciate any advise.
THX
THX
