Hey guys, I am in the middle of doing the base gasket mod on my '10 300.. I have about 75 hours total on the bike from brand new..
The stock squish if anyone is interested is 2.55mm with two green .030" base gaskets as delivered. Cranking compression full throttle was 130psi after about 10 kicks.
Anyway, onto the question at hand: I measured just the rod side clearance and it is at .040" (inches, not mm)... I thought they were supposed to be tighter than that but I could not find anything after doing a search.
Both piston rings are at .015" gap near the top of the bore squared up.
Any light that can be shed would be great, so I can maybe stop freaking out here. Thanks !
