How do you run blinkers with a trailtech REG REC? I have a DC system that charges the battery. I made a working mockup and the flasher relay does work, just not when it's plugged into the loom. Lights and horn stop working as soon as it's added.
12v to relay, relay to switch, switch to blinkers. Blinkers ground back to battery. All the other lights ground at the battery as well.
Thoughts?
Thoughts?
