You very likely won't get those clearances out of a stock head/S3 without dropping base gaskets and using the high high insert, I used a 1.3mm base gasket stack on mine, with the black insert and had 1.9mm clearance. Take out 0.6mm of gaskets would give me 1.3mm squish, but the compression would have been through the roof. I recall that even with 1.9mm I had a final UCCR of 12.5:1, and 13.5:1 is probably the absolute max you want to go on a 300.
When I set the 250 S3 head up, I used 1 x 0.5mm gasket and got 1.25mm squish using the black insert. Then had it machined to reduce volume and correct the compression ratio, still 14:1 after machining. Since then I've slipped another 0.1mm gasket in to time the ports for more top end, and also drop the comp some more for better over rev.
